Basic CSS
7 Apr 2004
Hey,
Can someone tell me how to change the color and font (remove the underline) of a link using CSS if possible, I dont want to apply it to the whole page, so can I use the <style> tags? I would also like to make the mouseover and vistied/active states so they always look the same.
Thanks a lot.
a:link
a:visited
a:active
a:hover
are the selectors you want
Add values to these depending on what state you want them in.
E.g. anchor link that has been visited
Code:
a:visited {color: #0000FF; text-decoration: none;}
All four selectors should be within the CSS.
:confused:
The <style> tags are for inline stylesheets. If you only want a certain text to have seperate styles, give that particular link a class.
