Basic Monitor that can be used in portrait
16 Jun 2005
Back in the UK
I need a new secondary screen after my 2 old Hyundai's finally packed in.
As there are no none widescreen monitors these days I want a screen I can use in portrait mode so it will fit on my desk.
Doesn't have to be anything special its a secondary after all and will mainly have TS, steam and a browser open on it.
Iiyama Prolite XB2380HS-B1 for £150
Don't know about overall quality, but it has pivot (which means the portrait mode) and it uses an IPS panel, which is pretty much a requirement for proper portrait usage (because TN panels will give inverse colors from wider viewing angles, and VA has the off-centre gamma shift).
