I haven't touched my pc since the beginning of last year and now I'd like to replace the Asrock 775Dual-VSTA board that I have. Primarily as it only has a x4 mode pci-express slot. I don't want to spend a lot if I can help it, around £50ish
I currently have:
e6300 with Freezer Pro64 cooler
7900gs
2 * 1gb PC5300
Any advice appreciated
edit - I was looking at the Gigabyte P31-DS3L but got a bit confused about it's memory limitations
http://www.giga-byte.com/Products/M...board&ProductID=2779&ProductName=GA-EP31-DS3L
I currently have:
7900gs
2 * 1gb PC5300
, if you got a standard version of the P45 chipset then you will get the latest technology which is always handy .
