Hello I have the Gigabyte Z68X-UD3H-B3 motherboard with a i5 2500K 3.3GHz CPU. I set the multiplier to 45x in the Bios and Windows reports 4.4GHz in System Properties. I ran a quick test on Prime95 (8 passes) and the screenshot shows the Voltages and Temps recorded in HWMonitor. I just wondered if anyone can check to see if it looks stable and if there is anything else I should consider tweaking.
Thanks
Thanks
