- 31 Oct 2005
- Leeds
Hi there, just looking for a bit of advice
Basically I have my website located
http://micholden.site50.net/
As you can see it's pretty basic but I'm learning
Anyway when you click on NUFC SHOP or
http://micholden.site50.net/shopaccess.html
You are required to log in (try ocuk and ocuk for user and passwords)
Works fine
BUT if you know the filepath you can bypass security
Example
http://micholden.site50.net/account.php
How do I go about making sure the account.php page only is viewable if you have logged in?
So far I have a very basic PHP script that looks at the login info provided, then looks to see if this matches the SQL database and redirects
Cheers for anyhelp
Works fine
Example
Cheers for anyhelp
