- 12 Jan 2011
Ok bit of a basic question regarding Corsair hybrid cooler h70, dripping sound. After hearing a sort of snagging sound from the PC fans I opened my PC for a check and a clean, found the CPU fan causing the sound and it seemed the dirtiest so I unscrewed the fans and radiator and cleaned it.
99% certain I put the fans back on the correct and the temps seem correct ie normal/max 30-35c (according to AI Suite) Without stress testing.
My main point is now its all back to normal there seems to be an excessive liquid sound like dripping. (no I haven't opened it up but I guess the temps change or malfunction would indicate a leakage)
Bit of a strange question but this is my first hybrid cooling and its slightly strange hearing liquid inside a PC, though I am use to hearing that sound from a radiator so Im guessing its normal? But did I do anything wrong in cleaning ie rotating the hybrid cooler.
Thanks if you read this its a bit babbly*
