A nice quick one after watching a brilliant review of water cooling an 810 I now know I can mount a triple 120 radiator 60mm thick (not sure of the technical term, new to water cooling) in the top but not with the room for push pull. The review claimed it was best to just use a 60mm rad w/o push pull.
Basically is the general consensus that the 60mm rad is worth it or would it be better to get a slightly thinner rad and use push pull, if so any ideas of which rad to use?
As a sneaky followup is their a way to find rad width within the name ie does 360=60mm? Some of the radiators do not give width and it can be quite confusing.
