basic regex question (PHP)
3 Oct 2009
I have a redirect plugin for my wordpress blog that allows rules based on matching regular expressions, which i do not understand at all.
I need a pattern that matches something like
/toy-models/tonka-blue/
and changes it to
/toys/tonka/
The base urls are always "/toymodels/" followed by one word, and a hyphen, and everything after the hyphen can be discarded.
So it's to search for the pattern:
"/toymodels/"<one word for a toy type><a hyphen><some stuff to discard>
and replace with
"/toys/"<the toy type found above>"/"
Any help?
PHP:
$url = "http://$_SERVER[HTTP_HOST]$_SERVER[REQUEST_URI]";
$pos = strpos($url, "-");
$newUrl = substr_replace($url, '', $pos);
header("Location: ". $newUrl);
Works providing there is only one dash...
There'll always be two (notice there's one in the "toy-models" and it's the bit after that I;m looking for the hyphen.
I should have been more clear though - I am using a wordpress plugin to set up custom redirects for a subset of the links on my blog. It needs regex input, I'm not directly accessing the server.
After many hours building up a huge headache, I think I've figured out something that works:
The string to Find: (/toy-models/)(\w*)-(\w*)
The string to Replace: /toys/$2/
