basic router for use with VM modem
Ish
Ish
11 Jan 2006
West Midlands
Hi
I need a basic router that will work with a VM router in modem mode. Wifi performance is not important as there is a Unifi AP used for that. The only requirement is that it must have 4 x gigabit lan ports.
What do you suggest? The cheaper the better.
Why would you want to connect a 'basic' router to the VM hub?
How would this be better than leaving the VM hub configured as router but with the wireless switched off?
If you're needing additional ports a cheap Gigabit switch is the answer.
If you really feel that you need to add a router what does it need to offer that the VM hub doesn't?
