GladlyShow us some stability testing on your 5.1 chip. XTU, Prime, Real bench etc... prove it!!!
Gladly
CPU:OCCT, large data set, 1 hour, PASS
Asus RealBench, Stress test 4 hours, PASS
Asus RealBench, H.264x10 loop, PASS
XTU, stress test, 8 hours, PASS
X264_v2, 10x loop, 16 threads, High prio, PASS
Cinebench R15
Single score: 203
Multi score: 1036
SuperPI, 32M
5.4GHz validation
For my usage, gaming, this is more than stable
For me at this specific price point X99 is king and does not need high speeed DDR4 to achieve this position.
8 Pack I am in full agreement, X99 is the superior platform and now DDR4 has come down so much I am failing to see the attraction of the new Skylake platform......
No need man 4790K junk on LN2. I still have some golden 4770K left that are.
But still a good chip yeah.
... plus you ran the 5820k @ only 4.2GHz for this bench?
Isn't it hard to find a 5820k that won't his 4.5 on good air cooling or AIO cooling now?
If skylake is only showing 2-3% faster compared to a 5820k at 6.7% lower clockspeeds... I'd be more keen to seen 4.5 vs 4.5.
Or is it that you are only testing without voltage boost?
I showed a very easy Overclock all can achieve on both chips. Stock volts or low volts. Sure good chips can do more.
Thanks for this, I was leaning towards X99 now its without question. Although I always wanted more cores anyway for Folding/BONIC.
Any deals for X99 Sabertooth with 5930k?![]()
for folding you can use loads of pcie lanes because it uses all the gpu power, however you dont need yo put the in sli/cf, you can run a mix of gpu's, i ran a 7970 and gtx670 in the same pc for a while.Why 5930 over 5820... are you planning tri or quad sli/crossfire?
