- 31 Oct 2005
- Leeds
Hey all, just need a point in the right direction on a few bits and bobs
in SQL
Using a field value in a query
I have a statement that replaces anything with a blank entry on 1 field and replaces it with EMPTY (This is hardcoded)
I wish to rather than hard code this, to feed the value from a field in test_table
i.e nvl(randomfield = 'I want my value from test_table here')
Secondly
Inserting query records into a table
I would like a bit of help inserting records into a table from a query
e.g
select surname,
a_hard_coded_value (e.g query number 1)
from test_table
into another_test_table (column1, column2)
Finally Identifing White Space
I wish to check the a certain column's field values do not have whitespace
e.g 'value' - is fine
but 'value ' -is flagged
in SQL
Secondly
e.g
select surname,
from test_table
