After having trouble with windows XP i decided now would be a great time to try linux (again), but this time properly and not in a virtual machine environment (which had awful performance, simply having vmware installed slowed down my xp boot time). After putting ubuntu on a usb drive and installing off that i have noticed i am going to need a few things.
First off, i noticed that by default there are power settings for when connected to AC and when on battery, but is there any way i can have some sort of display showing my current battery status, because so far nothing like that has shown up (although perhaps thats because i have been running on AC the whole time, i dont know).
Secondly, i have a clean install of XP pro as well (im hoping a clean install will be a bit better then my bloated old default lenovo install), the problem is that doesn't have any drivers so i would like to somehow create a folder on my ubuntu desktop that goes to my XP partition, so i can download drivers with ubuntu (which came with enough drivers for networking to work, and so connect to the net), and then open that folder and do a simple drag and drop, so when i load XP the drivers are there ready for me to use.
Finaly, is it just me or is everything in ubuntu 'bigger'? I'm running at the same resolution as my XP install, but things like the firefox window, and the text inside it just look bigger, it feels as if i am running at a lower resolution or something, yet the resolution is correct. Maybe its all just in my mind or something, but it does feel like that.
