In the future we are looking at changing to VMWare and using vSphere, with maybe 4 servers with ESXi on. At the moment I am just about to test VMWare and know very little about it other than the following (which may or may not be 100% correct)...
VMware ESXi - Install this onto a blank server. Acts as resources
vCenter Server - Central administrator for ESX/ESXi hosts connected on
a network. Used to created a cluster of ESXi hosts where the resources are linked
vSphere Client - Installs on a Windows machine and is the primary method of interaction with VMware vSphere. The vSphere Client acts as a console to operate virtual machines and as an administration interface into the vCenter Server systems
and ESX hosts.
At the moment my test setup is as follows...
HP Proliant DL120, 4GB RAM. VMware vSphere Client and vCenter server installed
I planned on putting ESXi on an old dell workstation but I now see it needs at least 2gb ram amongst other hardware. So I will move ESXi to the DL120 and install vCenter Server and vSphere on a workstation if possible
Can vSphere be installed and work correctly on the same machine as vCenter Server?
I have just been reading the following documentation
"After you install vCenter Server and the vSphere Client, you can configure communication between them. This chapter includes the following topics:..."
and ESX hosts.
