Basic wallpaper changer
2 May 2004
Hi,
Basically I'd like a piece of software that runs unobtrusively in the background (must have a tray icon though so I can easily open the options etc. if needed).
All I want to set on it is the folder where all my backgrounds are stored and the time to use each wallpaper before it's changed, so something nice and basic.
Thanks,
Craig.
do you mean a timed wallpaper rotator? I use one of those, or did you mean one where you can change it manually yourself?
If its for XP try "powertoys wallpaper changer" from ( http://www.microsoft.com/downloads/...6b-6851-4948-ab76-b5ff22d37d69&displaylang=en ) don't think it work with vista tho but im not sure.
Just checked and as long as you run it with compatibility for XP enabled it works fine on Vista
XP here so should be alright :)
Thanks very much :)
[Edit]
Just installed and it's 100% perfect :D
I used to use Wallpaper Changer, but only ever the option to change on reboot.
Would want it changing every x hours/days/mins really, but thanks very much for the link :)
