I'm looking to pick up a 980Ti on black Friday and then embark on my first water cooling adventure. After a lot of reading I still have some probably basic questions left.
If I buy a 980ti cooling block, can I simply rip the fan off any 980ti and use it? If this is the case surely buying a pricer Ti is a waste? And Could I assume the warranty would be voided instantly?
I'm planning to replace all my intake fans with radiators. If I don't water cool my Mobo/ram are they likely to overheat? (Case is 780t).
Is there any advantage to a separate pump/res to a combo one?
Thanks in advance!
Thanks in advance!
