- 19 Nov 2008
looking at getting a macbook for university and basicly i dont know much about them. and in need of some guidence.
1. a macbook will run a on a normal screen?
2. how well dose the bootcamp work? i will need it to be able to run CAD programs will it run any pc program?
3. will there be a large advantage of getting the normal macbook over the macbook white as the white is ddr2 and the normal one is ddr3
4. is it worth getting the basic modle and upgrading the ram and hd on your own?
if there anything elce i need to know that i might have overlooked?
thanks for any help
thanks for any help
