It's most likely to be 32mm (1 1/4 inch) if it's a bathroom basin, 40mm (1 1/2 inch) are typically used for kitchen sinks, baths, showers.
You can get a good idea by just holding a tape measure up to the pipes leading in/out of the trap, if it's under 40mm (35-36mm OD) get the 32mm one, if it's +40mm then get the 40mm one.
