- 7 Feb 2004
- North East
My basin waste started to leak last night; it turned out the nut underneath had snapped.
The waste I took out was siliconed in from above and below, with a rubber washer either side.
My research has led me to believe that plumbers mait is the correct thing to seal underneath. - a la
I've bought http://www.screwfix.com/p/unbranded-retained-basin-waste/57005 and it has a foam washer up top (which looks a bit pap tbh) and a rubber washer underneath.
I kept the rubber washers from the old waste, so was going to replace the washer above with the old rubber one.
What is the correct procedure to seal this properly?
I'm thinking
Waste - silicone - old rubber washer - silicone - basin - plumbers mait - nut
Don't bother with the rubber washer below?
Do I need to silicone the washer above, or should it seal with the pressure?
The overflow is built into the sink, so it runs in a channel and into the slot of the waste, if that makes any difference.
Any advice appreciated
I've pics of the parts if that's any help.
I'm thinking
