- 16 May 2004
- Derby
Hi. I have got a ageing Denon AVR 1909 surround receiver. It does DD and DTS HD sound modes and 7.1
I have just downgraded (in size and power but being fairly new, they sound hell of a lot better) my 5 speaker. 2 fronts, center and surrounds. This is set up for 5.1 the other 2 rears are still the older mission speakers which are still connected to the Denon but rarely used due to not much 7.1 and the XBOX One doesn't support it properly.
Anyway. The 5 speakers are these Pioneer beauties. The reason I went for these are from the reviews, budget and the general size and look. I am not into getting the best, but gear that sounds good to me within my budget and these sound very good indeed.
Right. Onto the issue at hand. My sub is an old Sony one which came as part of a package years ago. R0B75 could possibly tell you what package it came from. The sub itself is great, packs a good punch and fills the room. Well sort of.
Here lies my problem.
I can hear/tell where the bass is coming from whilst on my XBOX One and watching movies. I have googled this problem and subsequently jumped into my Denon settings and changed the crossover settings for the speakers.
The new speakers have a range of 100 Hz to 20Khz.
The sub has 50Hz to 60Hz (this is on the back-following the voltage. May have nothing to do with what I am asking but I'll stick in here anyway)
The speakers are very clear and crisp and I have the center speaker at +7 level. The rest are set at 0. I have the sub volume set at max on the unit itself and use the Denon to apply the right (to me any way) volume.
The current Xover settings are as follows.
F 110 Hz
C 100 Hz
S 110 Hz
SB 110 HZ
LFE 80Hz (sub mode is LFE and MAIN)
This setup sounds very good, nice vocals, sound effects. A lot clear then my other speakers. Now, the bass is good but I can really hear it in my left ear. It is situated next to the sofa pointing into the middle of the room but at a slight angle. If I get chance I will MS paint a lay out.
Can anyone give me some tips on getting this bass how it should be.
If you require more info etc please just ask.
Edit: Here is my room layout.
F 110 Hz
C 100 Hz
S 110 Hz
SB 110 HZ
