Hi guys I am looking for a simple script that a user can run to copy files from a local machine to a USB pen drive (f
. However I am not sure if its possible to script that if it detects another folder in the same destination with the same name then it asks the user what it should call this folder.
The idea behind it is that I want a end user to backup a specific folder to the USB every time they use it, but I would rather have a new folder name each time with the user specifying the date after the folder name.
Is that possible?
thank you.
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Is that possible?
thank you.
