I'm trying to create a bat file to automate a process of an exe... however I'm just wondering how to minimise the dos prompt while it processes the task?
Is it possible to keep processing and finish the bat file while the exe is open and running?
How are you launching the .bat? How about creating a shortcut to the .bat with the program set to run minimised and launch the shortcut rather than the .bat?
