Batch ACC convertion.
12 Jun 2005
Hi there,
I have an MP3 / WMA collected that I want to convert to itunes format, but I would like it to replace the original.
Is there an option in itunes to do this? Or is there a differnt program you can recommend
Thanks
dBpowerAMP may be able to do what you require, if it comes with the right codecs.
Why do you want to convert your music collection to AAC, though? iTunes and the iPod range can play MP3s, but other applications and MP3 players can't play AAC. You won't gain any extra quality by converting existing MP3/WMA files to AAC, either :confused:
Ill give that program a try......well my itunes phone is really penikity (hope spelt right) with mp3 and wma and some just wont transfer to the phone unless tehy are in the itunes format (aac i believe).....so if I convert all of the them to aac there wont be any trouble when transfering them :)
That is possibly the worst program I have ever had to use, and it doesn't do what i want as far as im concerned. but thanks for the suggestion :)
Anything else?
the programs you usually use must wipe your bum for ya cus thats the simplest program in the world :p il go now as i have nothing more to contribute
