batch file help please
4 Jan 2004
¯\_(ツ)_/¯
How to I change variable values?
I have a line
set virtualdrive=X
but is there someway I can do something like
virtualdrive = virtualdrive - 1
so virtualdrive becomes V?
Is virtualdrive =X , setting virtualdrive to a numeric value ?
If it is then you can use
set /A virtualdrive -= 1
instead of
If it is a letter then you will have to use a lookup table type idea to change virtualdrive value
IF virtualdrive == "X" then goto change1
goto continue
:change1
set virtualdrive = V
:continue
Currently in work iam writing batch files to archive data form several pc across and network and rar the data and transfer to a server.
Hope this helps you
