- 28 Aug 2003
- N Ireland
it is a little complicated
i want to make a bat file to run a cmd on a remote machine to update my media library.
i can do it manually using psexec from pstools, but have got lost trying to automate it
i need to things in this order (win7 machine locally, whs2011 remote machine)
get an elevated command prompt [on win7 machine]
change directory to c:\pstools [folder where psexec.exe is]
run psexec \\vail -u Administrator -p ******** C:\YAMJ\My_YAMJ_2libraries_combined.cmd [where vail is the remote pc and YAMJ is the folder containing the command to run]
thanks for any ideas
