As many of you probably know, there are some serious problems on the way with the nVidia 55nm and 65nm chips, that is nearly all of the most recent ones. It's a thermal cycling problem, causing a shear between the solder "bumps" and the substrate (PCB), similar to the Xbox 360's Red Ring of Death trouble. As it is a thermal cycling issue, it mostly affects laptops, particularly laptops that are going in/out of standby very often.
Came across a really interesting (and technically rich) three part article on my favourite tech tabloid:
http://www.theinquirer.net/gb/inquirer/news/2008/09/01/why-nvidia-chips-defective
http://www.theinquirer.net/gb/inquirer/news/2008/09/01/nvidia-should-defective-chips
http://www.theinquirer.net/gb/inquirer/news/2008/09/01/nv-should
These basically explain everything..
Anyway.. I'm about to recieve a new laptop (from OcUK) with one of the dodgy chips (they are all defective, it's just a case of wether or not they are defective enough to fail..)
Should I underclock the GPU, avoid standby, and hope that I don't see the problems, or let it fail and get a replacement when the chaos ensues?
The case/motherboard is made by Clevo, and as far as I know, they have modular graphics cards. So it should be easy enough to replace with them..
