Batch script
Man of Honour
17 Nov 2003
Southampton, UK
I need a batch script that can input the contents a file for a variable.
Computers.txt
Computer1
Computer2
Computer3
Loop
Code:
psshutdown -k -f -c -t 200 %variable% -m "Press cancel if you are still working"
I just need the syntax to input the variables and iterate.
Thanks
Burnsy
Try this:
FOR /f %%a in (Computers.txt) DO psshutdown -k -f -c -t 200 %%a -m "Press cancel if you are still working"
Don't forget the \\ on the computer names either in the file or in the batch script.
I do it with two batch files. The main reason I do this is I have different batch files for different areas at work. Makes it easy to adjust PSShutdown, and it also means I can use the same batch files to initialise other scripts (I use PSExec a lot).
Off .bat
psshutdown -k -f -c -t 200 \\%1 -m "Press cancel if you are still working"
areaname.bat
For %%A In(list computer names) DO Call off %%A
