This is a slightly weird one.
We have a mixer tap on the bath in our (quite) new bathroom. If you run the hot water, it works fine. If you turn the mixer a little to add in some cold it is initially fine, but then goes to just cold water quite quickly. Turning the whole thing off when you realise this and restarting it turned all the way to hot - you still get freezing cold water.
I'm not quite sure what's happening. Is it that the cold feed is overpowering the hot to the extent that it's even forcing cold water back up the hot pipe?
Is this a known thing that can happen, and if so what's the fix? Some sort of non-return valve?
