Hi,
I purchased one of these panels and am a little stuck. Basically the images on there suggest it is height adjustable from from 480mm to 560mm. I require a height of 550mm so assumed all was good.
The text in the listing contradicts this and says "Fully adjustable : 400mm to 530mm" - which I didn't read correctly.
However, if I sit the panel directly on-top of the plinth, it's exactly the correct height of 400+150mm.
I understand normally you screw the plinth behind the panel to get the required height - so my question is, is it possible/sensible to somehow vertically join the plinth and panel? Here's a picture of what I mean
Maybe wood glue along the seam? Or an additional piece of wood sitting behind screwed into both the panel and the plinth to join them, with some sealant along the seam?
Or am I fighting a losing battle
Thanks for any help!
