Caporegime
- 21 Jun 2006
When I moved in 3 years ago. The vents which have ducting all the way into the attic then out a vented tile on the roof had been taped up. I suppose this was to prevent heat from leaking out. I now understand why has the en suite and bathroom are always cold even with the heating on.
I removed the tape and the vents. There was no fan.
I need a decent ceiling mounted extractor fan with an auto shutter function. So it basically turns on with the light or seperate cord. Then closes off so no heat can escape after it's timer goes off.
Can anyone recommend a good ceiling extraction fan which these features?
I suppose I could always just block the vents and use the ones in the windows manually if it's always going to be an issue of losing heat.
