Fan speed selection is under the cover , humidity / timerit doesn't seem to have anything you can change settings wise.
While not technically pc related....
It wasLuckily it’s not in the pc section then![]()
Yeah well, it's for the Changing Rooms lot ! I've got a white oneWhy on earth would anyone want a red extractor fan?
It is clipped in four locations but as it's up against the ceiling I don't see how I can unclip them so to speak. An electrician put it in as the previous one had to be dewired.While not technically pc related....
Pretty sure it's clipped at 4 locations. If you look at the exploded image you can see 'tabs' on the rear at the top and the bottom.
Not sure why you want to take it apart though... it doesn't seem to have anything you can change settings wise.
Actually looking at it again might only be 'clipped' at the top... stick something thin under the bottom side and lever out gently (think tool like removing phone screen)... it might pop out.It is clipped in four locations but as it's up against the ceiling I don't see how I can unclip them so to speak. An electrician put it in as the previous one had to be dewired.
Thanks yeah I bent round a bit of a credit card plastic.Actually looking at it again might only be 'clipped' at the top... stick something thin under the bottom side and lever out gently (think tool like removing phone screen)... it might pop out.
