Bathroom light showing signs of rust
2 Mar 2009
Glasgow
IPx4 is only protected against splashes so steam/moisture/condensation etc can and will get in.
You could try something greater like IPx6 but there's still no guarantee that condensation/steam/moisture etc won't get in and do its thing as that isn't a specified requirement of IP ratings.
As mentioned above, material that doesn't rust is the only way to be certain.
