Bathroom questions
9 Dec 2009
Bristol
also remember if you have to get a new seat they are a pain to source and quite expensive
we have one when seat gets loose it is often a case of removing toilet to refix :(
I've got a rectangular toilet, there are some minor inconveniences definitely.
As already mentioned, if the seat ever breaks, PITA to replace if you don't have a top-clip seat.
Also the toilet mats with the U shape do not fit the base. The alternative is just to use a normal rectangular mat.
If I had a remodel or needed a replacement in the future, I'd just get a normal one tbh.
Thanks for the replies folks.
We're considering one of those baths with the taps in the middle rather than one end. With a small bathroom where the bath covers the width of the bathroom, once the bath is fitted presumably there's no way at getting at the underside of the taps if something needed doing?
No normally the bath panel is fitted in a way which - sealant aside - is non destructive to remove and service the hot/cold/waste. Whether that's button clips, some hook and look modern contraption or just plain screws, should be done that way.
Yes but once the panel is removed you're faced with a huge bathtub with the taps behind it. I can't see them being at all accessible from below once fitted.
If the tap side is on a stud wall you `could` access the taps via a hole/ access panel in the next room
That said I would rethink where you want the taps
I have that style of bath&taps and recently bought a basin wrench which I used for inaccessible bolts on a flush valve,
seems that wouldn't work for the taps though , and I'll need to look out for other tools,
maybe could hire them.
other than that issue, having the taps out of the way from shower end of bath, or angled end where you might put your head is good.
Taps that pop out of base are a bit rubbish though if you can stub your foot or stand on them when showering.
Looks like there was a panel in the other room as I suggested too
Seen that done on site too
NOT AN EASY JOB!
Success depend on access to one end of bath and being a contortionist :D
Fully tiled bathroom walls or partially tiled?
We were all for fully tiling the room but some friends said that this will be too cold in there and to partially tile the walls.
Tiles hold heat so if the room is heated and they are saturated they will retain heat longer. If you maintain a cold room and the tiles never saturate with heat they will always feel cold. If you want to take it further you can heat some of the walls from behind like underfloor heating and do away with radiators.
Ours is fully tiled and is possibly the coldest room in the house due to being on a north facing external wall. However the amount of bathroom time tends to be less than most other spaces in a home. Excluding female members maybe.
Again it is much easier to dry after a shower by wiping with a bare palm followed by a cloth. We never have a mould problem even with the cooler air.
Summarising fully tiled IMO is the best solution
Fully tiled here as well. I find it the best, I'd go for big massive tiles if I was to do it again so there is less grout in the shower area directly. I'm pretty sure they can use resin now to seal it and it'll be even better.
Agreed, our tiles are quite large, 18" × 12" sort of size. When i tiled our first bathroom in 1982 i used 4 1/4" square which took ages to do.
