Batman AC Frame Drops? Is my Card not enough for 60FPS
25 Nov 2011
The KOP
Hello I using a HD7950 OC 1005/1400 with an i5 2500k OC 4.3ghz and 8GB ram.
I downloaded the demo before I buy for testing I have settings set to 1080p res,
vsync enabled
Dx11 with tessellation on normal and FXaa to high. with game profile set to very high and even tried just high and it has same frame drops.
Now when on the ground fighting ect my game runs at 60fps all the time but once I start going up onto building I get big drops into 35/45 fps and it looks bad stuttering.
I had a look on google and seen that dx11 has issues when game first came out and was fixed in a patch has this demo got the fix?
Anyone here used a 7950 with this game and run 60fps at all times?
Thanks
DX11+PhysX are both FPS killers unless you have something like SLI GTX670/680's or Xfire 7970. Play in DX9 it still looks good DX11 adds little overall.
Unlikely to ever get fixed 2 patches & 6 months later still the same....
Thanks guys will try without dx11 I don't use physx because using amd card. Am not sure if I should buy this game seems a bad port.
Not a bad port at all, dx9 blows console versions out of the water. Just dx11 that is broken but it does not make it look that much better at all.
