Batman Arkham City FPS
Ive got it on full as well. Had a couple of slowdown bits when doing mega fights flipping between about 20 folk. Apart from that runs perfect on 1080 for me
I think Batman is known for having some dodgy DX11 performance issues... they did release a patch for it, but it seems to vary as to whether it makes DX11 work better or not. My pal installed it but didn't see much performance increase, yet on mine I've got everything + DX11 and I get a pretty steady FPS.
Do you have DX11 enabled? if so, that could explain it. DX9/10 (or whatever it uses when DX11 isn't in use) works perfectly on my pal's machine, yet DX11 has this issue. Could be the same as yours dude.
You got the latest patch etc installed? I'm on a 6970 2gb, i5 2500k, 8GB RAM btw.
had some mad slow down well more like slow motion it dropped that low on joker fight with like 20 folks and the ghost trains running through it defo a directx11 problem
580 SOC @ 960 you still get slow down with AA off and PhysX off. It's definitely a DX11 problem because with DX9 you can run butter smooth with everything on the highest setting including 32x CSAA
