Batteries - mAh, V and such - would it work?
25 Jun 2007
Surrey - Croydon
I was just wondering - say i had a 10.8v 4400 mAh laptop battery and i wanted more life for my laptop - maybe as an emergency backup - theoretically i should be able to hook up 9 AA batteries each with an 1800mAh battery life and then get a total battery life of 16200mAh?
im not expert but i was just wondering if this would actually work?
the same applies for a phone too 3.6v 1500mAh - 3x1.2=3.6 then then u get 5400mAh life?
would it work ?
thanks,
Nine 1800mAh batteries hooked up as you describe would give you a 10.8v 1800mAh battery.
You'd need to connect the batteries in parallel to get increases in overall capacity. Your 10.8v 16200mAh battery would require 81 1.2v 1800mAh cells.
Don't forget about how much current the laptop would be drawing from your DIY battery pack. 60w (random guess) at 10v (for easy math) would require 6 amps, I doub't an AA battery could safely output that. You would probably need 2 or 3 packs in parallel, and then you'd better make sure that each pack is equally charged.
Charging would be a problem too, you'd probably need to take the pack apart and charge the batteries in pairs (most chargers do it this way). I doubt you could safely charge the entire pack with the laptop power supply (it's not even a charger, that's most likely inside the laptop).
