Hi guys,
I've planned a couple of battery swaps and all the guidance I'm reading talks about softening the battery adhesive with alcohol/contact cleaner before you're able to remove the battery. Some of the videos I've seen use a needle or a tube/straw so that you can get the accurate penetration, very much like the ones you get with a can of WD40/GT-85.
Are there any kits/sprays that come with anything like this because all I have at the moment is capped bottles of isopropyl alcohol.
Thoughts?
Thoughts?
