BATTERY CHANGE
29 Apr 2010
Got to replace the little battery, the one that keeps the time etc.
Is there anything i should know before i arm myself with a screw driver?, or is it a simple case of "back off, old baterry out, new one in"
check to see if the manufacturer provided a service manual for your laptop, (Lenovo/IBM and dell especially) which will detail the specific process and order of taking it apart.
of not, then good luck.
