Hi there
Anyone here have much experience with battery voltage vs reported ecu voltage?
Our golf is acting up. when sat in traffic for a while it will pick up a horrible hesitation when you get on the throttle, it feel slike it will stall
ive been monitoring loads of ecu things, nothing obvious is going on (intake temp seems to vary a bit wildly though) but i have noticed ECU voltage dropping to 12.9-13.0 volts (with headlights, wipers, ac on)
Anyone had experience before of ecu volts causing running issues (obviously 0 volts will cause issues, so i thought id get that funny reply out the way for you)
