Anyone where i can get a replacement battery for the L300 that isnt too expensive. Prices seem to be around £50 which is expensive when the laptop is only worth around £100.
If you replaced your battery, where did you source it from?
Battery prices vary depending on demand it would seem , but you do.get what you pay for , cheaper batteries dont last as long and tend to drain when not in use. If you need a reliable good battery you'll have to pay a bit more.
