Had a car sat on the drive for a couple of months. Went to start it last week, and it was completely flat. Used a mains charger to charge the battery for a few hours, it started up and left it running for an hour. No problems.
Yesterday it was flat again - central locking worked, but just the dreaded 'click' when turning the key. I used the mains charger for 30 minutes, started it no problem, and left it running for about an hour. I went to check on it, and the car had stopped, and the battery was flat again. I thought that running it for an hour would have charged the battery a bit, but doesn't seem so. Also, is it normal for a car to cut out when it's running due to battery issue?
New battery time? Might it be anything else, like the alternator? Thanks!
