- 20 Mar 2003
- On the stool at the end of the bar
I have a slight issue with the battery on my fto. The negative terminal seems to have worn slightly but enough so that when you tighten up the clamp it doesn't grip it well enough to stay on. This has led to a rather unamusing incident when i was driving down the road and suddenly lost all power
I currently have the clamp duck taped to the terminal so that i can get about but need to know if there is any way i can solve this without buy a new battery?
Also, i have noticed that on the voltmeter it sits at around 14 but when the indicators are on it varies between 12 and 14 to the beat of the indicator! Is the battery on it's way out anyway?
Thanks in advance
Thanks in advance
