Caporegime
- 21 Jun 2006
So I need to dupe the charger into thinking the battery has some charge in it so it will start charging it.
This is on a weekend only car which I drive 1K miles a year i normally charge the battery every 2 months but it's been a bad winter and not done it in like 3 months and it's gone.
So i have the inside of a torch with 4 aa batteries hooked up to it. i don't have jump leads. i need to make a connection to the battery using the batteries so the charger then starts charging the battery as it will see some voltage there.
what would be the best wire to do a hack job with? ethernet? usb? hack off both ends cut in 2 then connect to either side of 4 aa batteries using the inside of a torch connection then connect to battery whilst charger is attached to battery.
best cable to use? speaker cable? i have some good copper speaker cable in attic.
