- 15 Jun 2009
- Bournemouth
I have a 2.5yr old macbook pro from just before the uni-bodys came out.
2 weeks ago the machine turning off when the battery reached 60%. Could turn it on and it would carry on till 20% then turn off rinse and repeat untill flat.
Move forward to yesterday when I noticed the track pad button didnt feel right, no click.
Turned over the machine and the battery has swollen and the casing is falling apart.
Called apple as the machine is covered and they have said to take it to be looked at by an Apple Store. He did say though that when they get old they swell up.
Do you think its likley it will be replaced or do you think due to its age they will tell me to buy a new one?
Nearest store is a fare distance and would be a hassle.
If it turns out I need to buy a new one, the travel etc would just add to the cost.
