Battery type difference
5 Apr 2010
On Your Screen
I need a new battery for my car but confused by the type number.
These are the ones am looking at:
Bosch Battery (S4 Battery 005 4 Year Guarantee)
Bosch Battery (S4 Battery 014 4 Year Guarantee)
What do the 005 and 014 refer to?
Cheers
there are set sizes for batteries, with set terminal configurations. those codes tell you what configuration youre buying, so you know youre getting a compatible battery
It's a 99' Honda Accord.
Those two options come up when I put in my reg in ECP website, not sure how accurate it is now!
Cheers y'all
Go to the Bosch website and it will show you the configurations of the different tyres. Just buy one that matches the same terminals that is currently in the car v
