Battery warranties
16 Jun 2009
Bucks
Over the last couple of days, my car has started showing signs that the battery is giving up. Just slower churning when I start it and a low battery voltage. This is since the weather turned a little colder which might just be coincidence.
It was bought from Halfords a year or so ago and came with a three year guarantee, which I still have the receipt for
Does anyone have experience of claiming for a failing battery under these guarantees?
What is the voltage showing? Get another garage to test it out as the voltage is only part of it.
I have heard that halfords can be a bit of a pain with batteries though, how true this is i'm not sure.
I discovered the battery '+' terminal was covered in that corrosion fluff. I cleaned it off and WD40'd it and it's all OK again. I'll give it a proper clean up to make sure.
I did read somewhere you can put a copper penny near the terminal and it will 'soak up' the corrosion, saving the terminal. So I'll try that.
Thankfully no need yet to test the 'guarantee'.
I know they're only 12v (sometimes 24) but I am so scared of car batteries. Something in my brain says don't touch electrics with wires that thick.
I remember disconnecting my battery once, I put a pair of marigolds on.
Apart from shorting the contacts is there any risk with them?
Whenever I disconnect the battery I get GF to put the last one back on. I really don't like the little 'crkk' noise it sometimes makes...
I once jump started my car using the jump leads the wrong way round on the other car. That was a big spark.
Apart from that I follow the rule of take the negative lead off first and put it back on last, which is sensible 'just in case'.
Try this: Get your left hand to touch the left terminal and your right hand to touch the right terminal. What happens? Nothing, as there isn't enough voltage to do anything. You need upwards of about 40-50v to give a shock without a conductor such as salt water.
:D
You could put a finger on each terminal and be ok, 12v it so low it's not really dangerous unless you do something silly like leave a spanner over the 2 terminals! :eek:
