Battlefield 2 problem
30 Nov 2005
Rotherham.
I installed BF 2 last night on my PC, but when trying to create an online account the screen just hangs showing account been created, the music still plays but nothing else happens. I can't use the windows kewy to minimise and quit and CRTL+ALT+DEL doesn't work either, I end up having to power my Pc down.
Has anyone else had this problem or know if it is a known fault?
Yes Ive had a similar problem in the past after I login the screen/game hangs and nothing happens for ages until I get a failed login message ..... this has always been due to problems at the EA/Dice end. Did you try again today ?
don't forget to patch it to 1.41 if you want to play online ... and don't worry if you dont get a lot of servers listed upon first server refresh as there is a few isssues atm with Gamespy. Hope it works for you .
No, no need to install that.
Also if it ever hangs on the login bit again just pull out your network cable, makes it time out quicker.
