"Problem - Memory Sanity Errors
Cause - Serial-ATA drives and Wrong Drivers
Fix - The "Memory Sanity" error seems to be being caused by Serial-ATA drives not having the correct motherboard drivers installed. Please check your drivers if you are having this problem. This is the only known fix but i do have reason to believe it does not always help, if so you could have faulty RAM, try running a program called Memtest86 to test your ram for errors. Also try removing a stick of RAM from the machine to see if it helps running on just 1 stick of RAM."
