Battlefield 2 - Single Player
12 Jun 2005
Might be without internet on my gaming rig for a while and I remember I used to play BF2 single player no-stop last time I had no internet.
Basically, I am looking for things to enhance the experience.
At the moment, I was wondering if there is any way to get all *** weapons for single player on v1.41 (I know its possible on V1.0), I'm just wondering whether it is possible for the latest version.
Is there a way I can easily get the standard 64 player maps on single player without having to mod the files? Has someone released an automatic installer for this?
At the moment I am downloading Project Reality mod as I have just found out that there is a single player version for that.
Any other ideas?
Thanks.
Already have googled, that's were I got the information I have already put in the OP.
I was looking for some specific stuff which I couldn't find conclusively on google.
Also looking for any recommendations.
You want to dig around for the AIX mod. Gives you 64 player bot maps with unlocked weapons + a lot more custom stuff. Its made for SP/Coop :)
Just installed project reality and i like some of the effects on it, its done quite well, although i don't like the blurred vision when you are getting shot at - quite annoying. Also don't like the fact you can't see who is on your team and the kits for the different sides are nearly the same.
Will look into that mod - thanks.
Just downloaded Project Reality which is like 2.5GB and the AIX mod is quite large too, but will make sure i download and try
There are addons that improve the AI drastically too, unfortunately I can't remember the mod name...
I assume you are talking about the Bot Changer? Changes a value from 0 - 1.0?
