battlefield 2
15 Sep 2006
Edinburgh
my mates having trouble with bf2 heres what he says any help much appreciated :)
"Im trying to uninstall battlefield 2 from my laptop after having insalled it and it
didnt complete the install properly. I have tryed reinstalling it again and i am
having the same problem with it not completing the install properly. I tried to play
the game and it plays fine... I tried then to patch it so i could play online with
my friends on the updated servers and it said it couldnt find the file / path to
patch it to i have tried uninstalling the game so i can reinstall it from scratch
and not just overwrite the files but every time u go to uninstall it it comes up
with 2 messages
first message
>SetupDLL\SetupDLL.cpp (469)
pAPP:Battlefield 2 (TM)
PVENDOR:DICE
PGUID:04858915-9F49-4B2A-AED4-DC49A7DE6A7B
$10.50.0.125
@Windows Service Pack 2 (6002) BT_OTHER 328.37
Setup has experienced an error
Please do the following:
-Close any running programs
-Empty your temporary folder
-Check your internet connection (internet based setups)
Then try to run the setup again
______________________________________
Error code: -5001
so i have scanned my comp with a reg cleaner and spy bot and antivirus and its fresh
as a daisy but no difference. please any and all information on how to have this game
uninstalled / error code fixed / patches installed would be great...
thanks for your time and consideration :D"
try using software your uninstaller trial version its agreat piece of software,sounds like you maye have registry files till left over from uninstallation,try this program to uninstall your programs instead of the lousy add/remove programs way,been using this for years now,its great
http://www.ursoftware.com/
ah oops can some one move this to pc section please? :)
thats what i get for posting while playing diablo 2 :)
