Battlefield 3 control issues?
Caporegime
18 Oct 2002
Lake District
I seem to be having problems with BF3 on the PC, during the quicktime events where you have to stab a rat, the right trigger doesn't register, I have to switch to using the mouse for those sections.
Is there a fix?
Nope, Dice have basically been ignoring the issue, despite the systems being in place on Xbox with the same controller.
BF4 still doesn't fully support controllers either. The implementation is better than BF3, but again the on-screen icons don't change to match the control input, and you can't adjust your load out in single player without using the mouse, nor can you adjust load outs or squads in multiplayer without using the mouse
Baffling because the games aren't dissimilar on the consoles so the control systems should be very easy to port across.
there is third party software you can use called xpadder, it lets you set up custom bindings. I used this, not perfect but it was the best solution I could find at the time.
